[mapguide-users] IIS 7.0 Forbidden when opening /mapguide/ (frombrowser and Maestro)
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Feb 16 09:31:34 EST 2010
Under "server extensions" in IIS, you have to enable the
isapi_mapagent.dll file.
If it is not already enabled, add a new extensions, and browse to the file:
C:\Program Files\OSGeo\MapGuide\Web\www\mapagent\isapi_mapagent.dll
On the mapguide/mapagent virtual folder in IIS, select properties and
configure.
Make sure the .fcgi points to same file as above.
In the "server extensions" there should be no " around the path,
in the virtual directory configuration, there should be " around the path.
If it does not work, try using the mapagent.exe instead:
C:\Program Files\OSGeo\MapGuide\Web\www\mapagent\mapagent.exe
It has worse performance, so you shouldn't keep it enabled.
I have also seen a case where removing and adding the extension and mapping
made the 500 problem go away.
Regards, Kenneth Skovhede, GEOGRAF A/S
On 16-02-2010 14:44, Bojan Franc @ FER wrote:
> The suggested link http://server.ip/mapguide/mapagent/mapagent.fcgi
> gives me...
> 500 - Internal server error.
> There is a problem with the resource you are looking for, and it
> cannot be displayed.
> I tought there was a problem with permissions reading the folder, but
> seems that is not the case.
> Do I have to "enable" fcgi in IIS configuration or something similar?
> Regards,
>    B. Franc
> ----- Original Message ----- From: "Kenneth Skovhede, GEOGRAF A/S"
> <ks at geograf.dk>
> To: <mapguide-users at lists.osgeo.org>
> Sent: Tuesday, February 16, 2010 12:40 PM
> Subject: Re: [mapguide-users] IIS 7.0 Forbidden when opening
>> Try entering the full url into Maestro:
>> If you use the shorter version, Maestro will attempt to use that
>> first, then try to append "mapagent/mapagent.fcgi",
>> but if the second attempt also fails, you get the error from the
>> short one.
>> On 16-02-2010 10:30, BojanFranc at FER wrote:
>>> Hi,
>>> I was running MGOS with Apache so far, now want to use it with IIS.
>>> A got a IIS configuration error somewhere, I think...
>>> I can open MapAdmin and MapAgent with no problems.
>>> http://server.ip/mapguide/mapadmin
>>> ... redirects me to login.php and works OK...
>>> ... works OK
>>> But when I try to open http://server.ip/mapguide/ from browser or
>>> connect
>>> from Maestro,
>>> I get ...
>>> 403 - Forbidden: Access is denied.
>>> You do not have permission to view this directory or page using the
>>> credentials that you supplied.
>>> I am using IIS 7.0 on a Win2008 R2 server. It's a clean install, I only
>>> changed some options in IIS to get PHP working.
>>> What am I missing?
>>> Regards,
>>>   B. Franc
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
