[mapguide-users] Re: Is it Possible to set Feature Label for a layer dynamically
SriRam007 binod_tripathy at yahoo.co.in
Tue Feb 23 02:17:45 EST 2010
hi,
Upto 5th step is done. I got the LayerDefinition in XML format and modified
the "text" tag but Could u please explain the 6th step little more. I m not
getting what exactly i need to do.
I am not sure should i change the "Text" tag for changing the label.
<Text>"Key"</Text> :: <Text>"Name"</Text>
I just replaced "Name" in place of "Key".
"Name" is a another property.
Finally i got that modified XML file in a string. Please guide me for the
remaining steps
6) Make the layer from step 2 point to the copy of the LayerDefinition
from step 5 (link 2)
7) Save the MgMap instance from step 1
8) Refresh the map on the client (developer guide)
thanks
View this message in context: http://n2.nabble.com/Is-it-Possible-to-set-Feature-Label-for-a-layer-dynamically-tp4590194p4617412.html
