[mapguide-users] Re: Is it Possible to set Feature Label for a layer dynamically
SriRam007 binod_tripathy at yahoo.co.in
Tue Feb 23 06:34:02 EST 2010
Utility.InitializeWebTier(Request);
        string myLayerName = "Districts";//layerSelect.Value.ToString()
        //args = Utility.GetRequestParameters(Request);
        //Query Qry = new Query(args);
        MgUserInformation userInfo = new
MgUserInformation(Session["ID"].ToString());
        MgSiteConnection siteConnection = new MgSiteConnection();
        siteConnection.Open(userInfo);
        MgResourceService resourceService =
siteConnection.CreateService(MgServiceType.ResourceService) as
MgResourceService;
        MgFeatureService featureService =
siteConnection.CreateService(MgServiceType.FeatureService) as
MgFeatureService;
        MgMap map = new MgMap();
        map.Open(resourceService, "Sheboygan");//For "Sheboygan" Replace
Utility.GetParameter(this.args, "MAPNAME")
        MgLayerCollection layers = map.GetLayers();
        ArrayList layerNames = new ArrayList();
        MgLayer layer = Utility.GetLayerByName(map, myLayerName);
        string s = layer.GetLayerDefinition().ToString();
        MgResourceIdentifier resId = new
MgResourceIdentifier(layer.GetFeatureSourceId());
        MgResourceIdentifier layerDefResId = layer.GetLayerDefinition();
        MgByteReader byteReader =
resourceService.GetResourceContent(layerDefResId);
        string layerDefinition = ReplaceXMLValue(byteReader);
        MgResourceIdentifier layerResId = new
MgResourceIdentifier("Session:" + Session["ID"].ToString() +
"//Districts.LayerDefinition");
        MgByteReader reader = new MgByteReader(layerDefinition, "text/xml");
        resourceService.SetResource(layerResId, new
MgByteReader(layerDefinition, "text/xml"), null);//layerResId, reader,
null);
        layer.SetLayerDefinition(layerDefResId, resourceService);
        map.Save(resourceService);
Please tell where i went wrong...
thanks waiting for ur reply...
View this message in context: http://n2.nabble.com/Is-it-Possible-to-set-Feature-Label-for-a-layer-dynamically-tp4590194p4618330.html
