[mapguide-users] RE: Problem with Studio 2010 +Flexible layouts Error
Mark Pendergraft markp at Meadgilman.com
Wed Feb 24 00:27:30 EST 2010
You have to set the projection in the applicationdefinition.xml.
MapGuide uses WKT in order to deal with projections.  Fusion is now
based around OpenLayers which uses Proj4js to handle projections.  So
you need to set the projection in both the MapDefinition (which you have
already done in MapGuide Studio) as well as in the Map element in the
ApplicationDefinition.xml file.  The ApplicationDefinition.xml file
resides in the same folder as the index.html file that you are browsing
to in your web browser.
Change your applicationdefinition.xml file in the folder you just
created to reflect the markups below:
<?xml version="1.0"?>
<ApplicationDefinition
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="ApplicationDefinition-1.0.0.xsd">
<TemplateUrl>fusion/templates/mapguide/padmini/index.html</TemplateUrl>
  <MapSet>
    <MapGroup id="map">
      <Map>
        <Type>MapGuide</Type>
        <SingleTile>true</SingleTile>
        <Extension>
            <ProjectionCode>EPSG:26911</ProjectionCode>
           <ProjectionDef>+proj=utm +zone=11 +ellps=GRS80 +datum=NAD83
+units=m +no_defs</ProjectionDef>
<ResourceId>Library://flexisample/map.MapDefinition</ResourceId>
          <SelectionAsOverlay>true</SelectionAsOverlay>
          <SelectionColor>0x0000FFA0</SelectionColor>
        </Extension>
      </Map>
      <Extension />
    </MapGroup>
  </MapSet>
View this message in context: http://n2.nabble.com/Problem-with-Studio-2010-Flexible-layouts-Error-tp4596619p4623862.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100223/c7b4dcc9/attachment.html
