[mapguide-users] Re: Unable to view-Mark
Mark Pendergraft markp at Meadgilman.com
Wed Feb 24 00:39:09 EST 2010
You have to set the projection in the applicationdefinition.xml.  MapGuide
uses WKT in order to deal with projections.  Fusion is now based around
OpenLayers which uses Proj4js to handle projections.  So you need to set the
projection in both the MapDefinition (which you have already done in
MapGuide Studio) as well as in the Map element in the
ApplicationDefinition.xml file.  The ApplicationDefinition.xml file resides
in the same folder as the index.html file that you are browsing to in your
web browser.
Change your applicationdefinition.xml file in the folder you just created to
reflect the markups below:
<?xml version="1.0"?>
<ApplicationDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="ApplicationDefinition-1.0.0.xsd">
  <TemplateUrl>fusion/templates/mapguide/padmini/index.html</TemplateUrl>
  <MapSet>
    <MapGroup id="map">
      <Map>
        <Type>MapGuide</Type>
        <SingleTile>true</SingleTile>
        <Extension>
            <ProjectionCode>EPSG:26911</ProjectionCode>
           <ProjectionDef>+proj=utm +zone=11 +ellps=GRS80 +datum=NAD83
+units=m +no_defs</ProjectionDef>
          <ResourceId>Library://flexisample/map.MapDefinition</ResourceId>
          <SelectionAsOverlay>true</SelectionAsOverlay>
          <SelectionColor>0x0000FFA0</SelectionColor>
        </Extension>
      </Map>
      <Extension />
    </MapGroup>
  </MapSet>
View this message in context: http://n2.nabble.com/Unable-to-view-Mark-tp4623889p4623895.html
