[mapguide-users] RE: Unable to view-Mark
Mark Pendergraft markp at Meadgilman.com
Wed Feb 24 01:48:33 EST 2010
I'm guessing you need to download the trunk version of Fusion via SVN.
There have been a lot of improvements (in my opinion) since the release
of MGOS 2.1.
-Mark
[mailto:ml-node+4623972-942910135-74987 at n2.nabble.com]
Sent: Tuesday, February 23, 2010 10:10 PM
To: Mark Pendergraft
Subject: Re: Unable to view-Mark
Hi mark,
i have changed the ApplicationDefinition.xml as per your
suggestions....but the problem is same...
<?xml version="1.0"?>
<ApplicationDefinition xmlns:xsi="
http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="
http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="ApplicationDefinition-1.0.0.xsd">
<TemplateUrl>fusion/templates/mapguide/padmini/index.html</TemplateUrl>
  <MapSet>
    <MapGroup id="map">
      <Map>
        <Type>MapGuide</Type>
        <SingleTile>true</SingleTile>
        <Extension>
         <ProjectionCode>EPSG:26911</ProjectionCode>
        <ProjectionDef>+proj=utm +zone=11 +ellps=GRS80 +datum=NAD83
+units=m +no_defs</ProjectionDef>
<ResourceId>Library://flexisample1/map1.MapDefinition</ResourceId>
          <SelectionAsOverlay>true</SelectionAsOverlay>
          <SelectionColor>0x0000FFA0</SelectionColor>
        </Extension>
      </Map>
      <Extension />
    </MapGroup>
  </MapSet>
  <WidgetSet>
my data is zoomed  out (almost as a single point) in the browser.
After zooming In iam able to see the map...but the feature is not
selecting.............
In feature resource also  the coordinate system is
UTM83-11 (UTM with NAD83 datum, Zone 11, Meter; Central Meridian 117d W)
In Map definition also
In Application Definition also
then what might be the problem???????????
plz see the screen shot once...................
View message @
http://n2.nabble.com/Unable-to-view-Mark-tp4623889p4623972.html
To unsubscribe from Re: Unable to view-Mark, click here
< (link removed)
pbG1hbi5jb218NDYyMzg5NXw0NzQwNDE0Njk=> .
View this message in context: http://n2.nabble.com/Unable-to-view-Mark-tp4623889p4624055.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100223/54afcbf3/attachment.html
