[mapguide-users] MgApplicationException: Cannot create any more connections to the OSGeo.SDF FDO provider
Zac Spitzer zac.spitzer at gmail.com
Thu Feb 25 04:15:12 EST 2010
2.2 should help here a lot when it's released, it uses the same ACE
threads approach
which MG uses on linux for on windows
in the meantime, have you tried tweaking serverconfig.ini values?
also you might have an issue with your map, how long does it take to display?
z
On Thu, Feb 25, 2010 at 8:07 PM, Vittorio Ricchiuto
<vittorio.ricchiuto at hsh.it> wrote:
> Hi all,
> I have a problem with MGOS 2.1.
> We’re doing a test on a job with 4 concurrent connections, but but it
> happens that server crash and was forced to reboot the entire server running
> with a lot of other applications.
> The error message is  “Cannot create any more connections to the OSGeo.SDF
> FDO provider”
> On http://trac.osgeo.org/mapguide/ticket/462  says that the problem was
> solved by 2.1 version, but this seems not to be.
> Any ideas?
> PS: Sorry for my English
> Thanks,
> Vittorio Ricchiuto
> GIS Applications Developer
> HSH Informatica e Cultura srl
> Via Conversi, 92
> 75100 MATERA
> tel. 0835 388125 - fax 0835 269814
> email: vittorio.ricchiuto at hsh.it
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
