[mapguide-users] Re: EXAMPLE: Serving MapTiles directly
Pietro Ianniello pietro.ianniello at gmail.com
Fri Feb 26 03:37:32 EST 2010
Hi Rodolfo,
I have installed chrome 4 [portable from softpedia] and it works. I have
installe FF3.5.8 italian [portable apps, because I have 3.6 installed] and
it works.
For IE7 have you tried the left div if it works? I suspect you will get
missed tile even there.
To test delete cached files on the hard disk [remove
"C:\OSGeo\MapGuide\Server\Repositories\TileCache\Samples_Sheboygan_MapsTiled_Sheboygan"].
Perhaps you should decouple the two divs by commentig out the 2 lines:
mg_map.events.register("zoomend", mg_map, setZoomHttp);
mg_map.events.register("moveend", mg_map, moveHttp);
in the html.
[for Kenneth Skovhede: In windowsXP even using adsutil won't work.]
Pietro Ianniello.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100226/81112037/attachment.html
