[mapguide-users] Re: Using Mapguide OS with OpenLayers Setting Layer Visibility
durrrr paul.nicholson at capita.co.uk
Fri Feb 26 10:29:08 EST 2010
Thanks Pietro,
Will that not just hide the entire map though...?
My map is made up of 5 mapguide layers rendered by OpenLayers as 1 baselayer
image (I think!?)
will i not have to query mapguide again (server side) and then refresh the
map with javascript so that the map then appears with only 4 layers showing?
e.g. In maestro i have the following layers:
Os_250k
Os_50k
Os_25k
Os_10k
Countys
When these layers are renderd in OpenLayers they appear  as "MyMap" as a
base layer.
If i want to hide the Countys layer i must have to send a php request to the
server, i cant just do it client side can i? even if i do know the layer
object Id.
Thanks again
View this message in context: http://n2.nabble.com/Using-Mapguide-OS-with-OpenLayers-Setting-Layer-Visibility-tp4638383p4639768.html
