[mapguide-users] WMS connection config in MGOS 2.1
iaguilera isidoro.aguilera at aplicad.com
Mon Jan 4 12:04:54 EST 2010
I'm trying to do a WMS connection to the next WMS service:
http://www.idee.es/wms/PNOA/PNOA
and layer: pnoa.
I want to configure de coordenate system to EPSG:23030, so I included the
next config.xml file, but the connection doesn't work. Without config.xml
file the connection works, but I need to specify the coordinate system.
Where's the problem?:
<DataStore xmlns:fdo="http://fdo.osgeo.org/schemas"
xmlns:gml="http://www.opengis.net/gml"
xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns="http://fdo.osgeo.org/schemas"
xsi:schemaLocation="http://fdo.osgeo.org/schemas FdoDocument.xsd">
  <xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
targetNamespace="http://fdo.osgeo.org/schemas/feature/WMS"
xmlns:WMS="http://fdo.osgeo.org/schemas/feature/WMS"
elementFormDefault="qualified" attributeFormDefault="unqualified">
    <xs:element name="PNOA" type="WMS:PNOA" abstract="false"
substitutionGroup="gml:_Feature">
      <xs:key name="PNOAKey">
        <xs:selector xpath=".//PNOA"/>
        <xs:field xpath="Id"/>
      </xs:key>
    </xs:element>
    <xs:complexType name="PNOA" abstract="false">
      <xs:complexContent>
        <xs:extension base="gml:AbstractFeatureType">
          <xs:sequence>
            <xs:element name="Id">
              <xs:simpleType>
                <xs:restriction base="xs:string">
                  <xs:maxLength value="256"/>
                </xs:restriction>
              </xs:simpleType>
            </xs:element>
            <xs:element name="Image" type="fdo:RasterPropertyType"
fdo:defaultImageXSize="800" fdo:defaultImageYSize="600">
              <xs:annotation>
                <xs:appinfo source="http://fdo.osgeo.org/schemas">
                  <fdo:DefaultDataModel organization="Row" bitsPerPixel="32"
tileSizeX="100" tileSizeY="100"/>
                </xs:appinfo>
              </xs:annotation>
            </xs:element>
          </xs:sequence>
        </xs:extension>
      </xs:complexContent>
    </xs:complexType>
  </xs:schema>
  <SchemaMapping provider="OSGeo.WMS.3.1" name="WMS"
xmlns="http://fdowms.osgeo.org/schemas">
    <complexType name="PNOA">
      <RasterDefinition name="Image">
        <Format>png</Format>
        <Transparent>false</Transparent>
        <BackgroundColor>0xFFFFFF</BackgroundColor>
        <Time>current</Time>
        <Elevation>0</Elevation>
        <SpatialContext>EPSG:23030</SpatialContext>
        <Layer name="pnoa">
          <Style/>
        </Layer>
      </RasterDefinition>
    </complexType>
  </SchemaMapping>
</DataStore>
View this message in context: http://n2.nabble.com/WMS-connection-config-in-MGOS-2-1-tp4250883p4250883.html
