[mapguide-users] Does MGOS use worldfiles?
Hardt preinhart at environcorp.com
Tue Jan 12 09:08:54 EST 2010
No, when I add the layer to a map, then set the initial view of the map using
the ad hoc button, I get -10000000 and 10000000 in the X Y fields.
And when I view the map I have a white map.
Andrew DeMerchant wrote:
> I don't think that a world file can have the coord system info in it, so
> having the coord system show up as local_cs isn't unusual. when you
> preview the layer, is it not in the right place?
> On 1/12/2010 10:02 AM, Hardt wrote:
>> It seems that they don't for me.
>> When I create a dataconnection with GDAL provider, I add my .jpg and .jgw
>> files, but then the config file is empty, and the coordinate system is
>> LOCAL_CS["*XY-MT*",LOCAL_DATUM["*X-Y*",10000],UNIT["Meter",
>> 1],AXIS["X",EAST],AXIS["Y",NORTH]]
>>> World files work fine in MGOS - at least they have and do for me...
>>> Andrew
>>> On 12/8/2009 11:38 AM, Hardt wrote:
>>>> Hi,
>>>> I am still fighting with MGOS 2.1 to have nice rasters.
>>>> I wondered if MGOS uses worldfiles or if they are useless?
>>>> Thanks,
>>>> Hardt
>>> 	*Andrew DeMerchant*
>>> *Computer Technologist*
>>> ph.1-877-2GEMTEC x.163
>>> fax 506-453-9470
>>> /GEMTEC Limited<http://www.gemtec.ca>
>>> /191 Doak Road
>>> Fredericton, NB, Canada
>>> E3C 2E6
>>> This e-mail message (including attachments, if any) is confidential and
>>> may be privileged. Any unauthorized distribution or disclosure is
>>> prohibited.  Disclosure to anyone other than the intended recipient does
>>> not constitute waiver of privilege.  If you have received this e-mail in
>>> error, please notify us and delete it and any attachments from your
>>> computer system and records.
>>> Ce courriel (y compris  les pièces jointes) est confidentiel et peut
>>> être
>>> privilégié.  La distribution ou la divulgation non autorisée de ce
>>> courriel est interdite.  Sa divulgation à toute personne autre que son
>>> destinataire ne constitue pas une renonciation de privilège.  Si vous
>>> avez
>>> reçu ce courriel par erreur, veuillez nous aviser et éliminer ce
>>> courriel,
>>> ainsi que les pièces jointes, de votre système informatique et de vos
>>> dossiers.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> 	*Andrew DeMerchant*
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> E3C 2E6
> Ce courriel (y compris  les pièces jointes) est confidentiel et peut être
> destinataire ne constitue pas une renonciation de privilège.  Si vous avez
> reçu ce courriel par erreur, veuillez nous aviser et éliminer ce courriel,
> dossiers.
View this message in context: http://n2.nabble.com/Does-MGOS-use-worldfiles-tp4133221p4291745.html
