[mapguide-users] Ajax Viewer and Digitizing - may be a bug
psciga scigalla at battefeld.com
Fri Jan 15 11:13:36 EST 2010
Hi Stefan,
thanks for replay. So I will try it next days with MGOS 2.1.
Regards,
Peter
S.Dalakov wrote:
> Hi Peter,
> Sorry for the delayed reaction.
> Unfortunately I didn't manage to find a solution. In fact, I have not
> tried very hard, because the workaround fitted OK with my workflow.
> Regards : Stefan
> psciga wrote:
>> Hi Stefan,
>> have you solved it? I have exactly the same Problem with the
>> DigitizeLineString()-function.
>> Regards,
>> Peter
>> S.Dalakov wrote:
>>> Hi all,
>>> I encountered a strange bug with the Ajax Viewer. I had a module for
>>> digitizing polygons, which was placed as InvokeURL command in the Task
>>> Pane. Now I transformed it to an InvokeScript command and it is started
>>> through the top toolbar as a part of a Flyout - drops down in a menu.
>>> The bug is that, when I click on this dropdown menu to activate the
>>> DigitizePolygon function, the first vertex of the polygon is
>>> automatically placed where I have clicked to activate the function - the
>>> point on the map that was behind the menu. My workaround in this
>>> situation is to fire an alert box, displaying a message, which clears
>>> the buffer and then everything goes like expected.
>>> Has any body noticed such an effect / defect / bug? Is it possible to be
>>> a bug in my code ?
>>> The behavior is the same in IE, FFox and Safari
>>> It is MGOS 2.02
>>> Stefan Dalakov
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Ajax-Viewer-and-Digitizing-may-be-a-bug-tp2216718p4399567.html
