[mapguide-users] RE: IIS Configuration of Mapguide OS - testing web server extensions fails
padmini godavarthi godavarthi.padmini at gmail.com
Thu Jan 21 05:21:46 EST 2010
Hi Kenneth,
Thanks for you reply.
   Afterinstalling mapguide opensource 2.1
1) i found that MapguideApplicationPool was Created in the IIS.
In side that pool therewere 3 folders created named as
Mapadmin
MapviewerAjax
Mapagent
But the mapadmin and Mapagents are working properly but i think the problem
is with MapviewerAjax
I previously installed Mapguide Opensource 2.0 on Windows XP but its working
properly
2)Second thing is that regarding pemissions, i logged as  a system
Administrator butweb server extensions is not working.
Note:i dont have VS2005 in my system.only .net framework is
there..............
How can i resolve this problem??????????????
Regards,
Padmini G.
View this message in context: http://n2.nabble.com/IIS-Configuration-of-Mapguide-OS-testing-web-server-extensions-fails-tp1804217p4432836.html
