[mapguide-users] RE: IIS Configuration of Mapguide OS - testing web server extensions fails
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri Jan 22 03:16:01 EST 2010
If you can find the exact line of code that causes the problem,
that would help.
If you have the exact problem that is listed in the post,
have you tried setting permissions to "Everyone" -> "Full" on the file
and folder?
Regards, Kenneth Skovhede, GEOGRAF A/S
On 22-01-2010 07:19, padmini godavarthi wrote:
> Hi Kenneth,
> Thanks for your reply .
> I followed the guidelines given in ul. the problem is solved.
> Now Actually my poblem is that while running on  show in browser the
> exceptions comes that
> System.Security.Permissions.SecurityPermission
> I have seen the same error posted by somebody and replied by you
> http://n2.nabble.com/security-exception-webconfig-ini-td1813100.html#a1813100
> i think that the problem might be with IIS (Application Pools).iam unaware
> of that.so iam unable to find the problem as well as solution.
> In my system
> IIS
> Application Pool
> |___MapguideApplication Pool
> Default Web site
> SharePoint -80
> |---Mapadmin
>        MapAgent
>        MapviewerAjax
>    is there
> so plz giv me guidence so that it would be helpful to me...
> Note:-Iam logged as a system Administrator
