[mapguide-users] Re: How to bring Task Pane back?
Steve G steve.golden at morganhill.ca.gov
Fri Jul 16 18:21:35 EDT 2010
Thanks for the script.  It works.  However, I've been playing around and
found that it doesn't work if the taskpane is not visable when the map loads
up?  Example - The xml for the map definition file has:
<TaskPane>
    <Visible>false</Visible>
Can I invoke a script which turns the taskpane on?  I am still working with
MGOS 2.1.
Thanks.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-bring-Task-Pane-back-tp4976596p5304089.html
