[mapguide-users] Fusion - Printing Base Layer
Berdel, Brian brian.berdel at mcmtrans.com
Thu Jul 22 09:03:52 EDT 2010
Is there a parameter in the print and savemap widgets to print / save the baselayer in fusion?
If you have two maps only the top level map will print.
Thanks,
Brian
Important notice to recipients:
Copies of documents that may be relied upon by you are limited to the printed copies (also known as 'hard copies') that are signed and sealed by the Engineer and/or Land Surveyor. Files in electronic formats, or other types of information furnished by the Engineer and/or Land Surveyor to you such as text, data or graphics are for your convenience only. Any conclusions or information obtained or derived from such electronic files will be at the user's sole risk. When transferring documents in electronic formats, the Engineer and/or Land Surveyor makes no representation as to long-term compatibility, usability, or readability of the documents resulting from the use of software application packages, operating systems or computer hardware differing from those used by McMahon Associates, Inc. at the beginning of the project.
