[mapguide-users] Re: Commercial Map Service Help
Mike Adair madair at dmsolutions.ca
Thu Jun 3 14:55:52 EDT 2010
It's hard to say what is wrong without seeing your application (and the
Firebug output), however based on the AppDef snippet in your previous
message I would first try expanding the Google layer definition some
more (however I suspect most of these values should be set as the
default already):
      <Map>
        <Type>Google</Type>
        <Extension>
          <ResourceId>google</ResourceId>
          <Options>
            <name>GoogleLayer</name>
            <type>G_NORMAL_MAP</type>
            <isBaseLayer>true</isBaseLayer>
            <sphericalMercator>true</sphericalMercator>
          </Options>
        </Extension>
      </Map>
If that doesn't fix it, I would suggest you post your full AppDef file
here so it can be tested.
Mike
LLEUNDD wrote:
> Thanks Jason -
> I updated the Fusion as described here: http://svn.osgeo.org/fusion/trunk
> and downloaded the latest fusion here: http://download.osgeo.org/fusion/
> (fusion-2.0.0-RC1)
> All the instructions for updating fusion were followed as per
> http://svn.osgeo.org/fusion/trunk/INSTALLATION.TXT
> I seem to be getting the same error though as mentioned above.
> When I try loading the Sheboygan-m map from the sample folder without
> changing the index.html or applicationdefinition.xml file, it loads just
> fine.
> If I update the index.html file and applicationdefinition.xml file as
> instructed - the error comes up.  I am beginning to wonder if by replacing
> the entire mapset contents with just the google and sheboygan-m as listed in
> the instructions is incorrect.
> I don't know enough about this - if someone can help I would be grateful!
> Cheers!
   Michael Adair
   Senior Software Architect
   DM Solutions Group Inc.
   Office: (613) 565-5056 x26
   http://www.dmsolutions.ca
   http://research.dmsolutions.ca
