[mapguide-users] Performance of MapGuide on a Virtual Server
Zac Spitzer zac.spitzer at gmail.com
Wed Jun 30 02:33:13 EDT 2010
Can you try out with the sheboygan sample and report how long that takes?
On 30 June 2010 12:09, Jason Birch <jason at jasonbirch.com> wrote:
> It's really hard to say. Have you done any profiling on the server to
> determine whether you're disk/memory/cpu-bound? What do you mean by
> close? What's the throughput of the network connection?
> What version of mapguide are you running? What's your data source?
> How many layers do you have in your map?  Are you applying appropriate
> display ranges for the data?
> Virtualization can be a measurable performance factor, especially for
> disk access or if your farm is experiencing heavy resource contention.
>  It's not necessarily the first place I'd look though. An optimized
> map on a properly-resourced virtual machine shouldn't be
> order-of-magnitude worse than the same on equivalent hardware.
> Jason
> On 2010-06-29, oshan <icycool at inbox.com> wrote:
>> Hey Guys
>> I am running mapguide on a virtual red hat Linux server.
>> Specs:
>> Intel(R) Xeon(R) CPU X5570  @ 2.93GHz
>> RAM 3GB
>> It take about 1 minute to load Ajaxviewer in firefox (cold start) and I am
>> very close to the actual server. I have about 10 data sources. The map
>> package is about 19MB.
>> I am wondering if it will make a big difference to the performance if
>> mapguide is moved to a dedicated server?
>> Thanks
>> Oshan
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/Performance-of-MapGuide-on-a-Virtual-Server-tp5234442p5234442.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
