[mapguide-users] Re: Is it possible to maintain a separate viewerfiles for a project
Jackie Ng jumpinjackie at gmail.com
Wed Mar 10 07:15:43 EST 2010
Viewer files are global for a single mapguide installation. Since you're
using .net, the easiest solution is to copy  the www directory to a separate
folder, and create a new virtual directory from that folder that is
identical to your original /mapguide virtual directory.
Then you can do all your customisations in one virtual directory while the
other one remains the same.
- Jackie
View this message in context: http://n2.nabble.com/Is-it-possible-to-maintain-a-separate-viewerfiles-for-a-project-tp4708311p4708617.html
