[mapguide-users] RE: MapGuide with Openlayers (Searching for Detailed yet Simple Development Examples)
Chris Gountanis cgountanis at mpowerinnovations.com
Thu Mar 18 17:50:30 EDT 2010
Pietro this helps and I will try this out. I have worked with Coldfusion and
.NET using MapGuide API and I have played with the MapGuide OL example till
I was blue in the face. This helps fill in the gaps between those. Your
options (useOverlay=true, useAsyncOverlay=true) with [show/hide] should at
least get me showing a map with the ability to turn on and off layers with
JavaScript. If we had more examples like this we might bring open source
back to mapguide open source J I will tell you what, time allowing as I get
basics as stated in my first post cleaned up and documented I will have no
problem reposting the summaries on MapGuide WIKI for others to benefit from.
Regards,
Chris Gountanis
[mailto:ml-node+4759356-1665868586-98072 at n2.nabble.com]
Sent: Thursday, March 18, 2010 4:05 PM
To: Chris Gountanis
Subject: Re: MapGuide with Openlayers (Searching for Detailed yet Simple
This is a simple example using ASP.NET and OpenLayers using the usual
Sheboygan example. Sorry but I don't know yet how to load legend. For the
selection I have not tried yet, but OpenLayers accepts the xml returned by
selection in params, so using selection  as in MapGuide Dev''s guide should
work [see comment in code] - I didn't tested.
For tooltips you can query the server on mouse move, standard AJAX stuff,
but I would do it only in intranets or with big server power, otherwise you
would be bombing the server with requests.
To have more layers, you can add an overlay [in options useOverlay=true,
useAsyncOverlay=true, the second only for MapGuide>=2.1] using the same
session, just changing show/hide layers string.
And yes, to come up with the following code was really hard!
NOTE: call in Global.asax MapGuideApi.MgInitializeWebTier(Webconfig Ini
Physical Path);
Devs guide says this shoul be called on every request, I call it once in
Global.asax, and it works. I don't know more and haven't found any info!
<%@ Page Language="C#" %>
<%@ Import Namespace="OSGeo.MapGuide" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<script runat="server">
    private string _strSessionId = "";
    private string _mapName = "";
    string _csvShowLayers = "";
    string _csvHideLayers = "";
    protected string GetMapName()
        return _mapName;
    protected string GetMapSession()
        return _strSessionId;
    protected string GetShowlayers()
        return _csvShowLayers;
    protected string GetHidelayers()
        return _csvHideLayers;
    private void MgDispose(MgDisposable obj)
        if (obj != null) obj.Dispose();
    protected void Page_Load(object sender, EventArgs e)
        MgUserInformation userInfo = null;
        MgSiteConnection siteConnection = null;
        MgSite site = null;
        MgResourceIdentifier resourceId = null;
        MgMappingService mappingService = null;
        MgMap map = null;
        MgResourceService resourceService = null;
        MgSelection selection = null;
        MgLayerCollection lColl = null;
        MgLayerBase layerBase = null;
        MgResourceIdentifier sessionIdResourceIdentifier = null;
        try
            userInfo = new MgUserInformation("Anonymous", "");
            siteConnection = new MgSiteConnection();
            siteConnection.Open(userInfo);
            site = siteConnection.GetSite();
            _strSessionId = site.CreateSession();
            //Save new mapguide session
            userInfo.SetMgSessionId(_strSessionId);
            resourceId = new
MgResourceIdentifier("Library://Samples/Sheboygan/Maps/Sheboygan.MapDefiniti
on");
            _mapName = resourceId.GetName();
            //Layers objectId
            mappingService =
(MgMappingService)siteConnection.CreateService(MgServiceType.MappingService)
            map = new MgMap();
            resourceService =
siteConnection.CreateService(MgServiceType.ResourceService) as
MgResourceService;
            map.Create(resourceService, resourceId, _mapName);
            lColl = map.GetLayers();
            int iMax = lColl.Count;
            //Let's show only Districts & Hydrography:
            StringBuilder sbShow = new StringBuilder();
            StringBuilder sbHide = new StringBuilder();
            int iHid = 0, iShow = 0;
            for (int i = 0; i < iMax; ++i)
                if (null != layerBase) layerBase.Dispose();
                layerBase = lColl[i];
                string layername = layerBase.GetName();
                if (layername == "Districts")
                    if (iShow > 0) sbShow.Append(",");
                    sbShow.Append(layerBase.GetObjectId());
                    ++iShow;
                else if (layername == "Hydrography")
                    ++iShow;
                else
                    if (iHid > 0) sbHide.Append(",");
                    sbHide.Append(layerBase.GetObjectId());
                    ++iHid;
            _csvHideLayers = sbHide.ToString();
            _csvShowLayers = sbShow.ToString();
            //Necessary to show maps:
            selection = new MgSelection(map);
            selection.Save(resourceService, _mapName);
            sessionIdResourceIdentifier = new
MgResourceIdentifier(String.Concat("Session:", _strSessionId, "//",
_mapName, ".", MgResourceType.Map));
            map.Save(resourceService, sessionIdResourceIdentifier);
        catch
            throw;//TODO: Handle exceptions
        finally
            MgDispose(sessionIdResourceIdentifier);
            MgDispose(selection);
            MgDispose(layerBase);
            MgDispose(lColl);
            MgDispose(resourceService);
            MgDispose(map);
            MgDispose(resourceId);
            MgDispose(mappingService);
            MgDispose(site);
            MgDispose(siteConnection);
            MgDispose(userInfo);
</script>
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
    <title></title>
    <script type="text/javascript"
src="http://www.openlayers.org/api/OpenLayers.js"></script>
    <style type="text/css">
    #map_mg
        width: 500px;
        height:500px;
        float: left;
        border:solid 1px #000;
    </style>
</head>
<body onload="init()">
        <form id="form1" runat="server">
    <div>
        <h2>Qick example: TODO: Dispose all map guide objects, use
StringBuilder, etc...</h2>
        <h3>Showing only Districts/Hydrography</h3>
    </div>
        <div id="map_mg">
        </div>
    </form>
    <script type="text/javascript">
        var addrs = "http://localhost/"; //TODO: get the address of your
server
        var mg_url = addrs +
"mapguide/mapagent/mapagent.fcgi?USERNAME=Anonymous&";
        var metersPerUnit = 111319.4908;  //TODO: get value returned from
mapguide on server side
        var inPerUnit = OpenLayers.INCHES_PER_UNIT.m * metersPerUnit;
        OpenLayers.INCHES_PER_UNIT["dd"] = inPerUnit;
        OpenLayers.INCHES_PER_UNIT["degrees"] = inPerUnit;
        OpenLayers.DOTS_PER_INCH = 96;
        var _map = null;
        function init() {
            //TODO: get extent from mapguide on server side
            //      I usually get extent on server side, I don't write here
code, because Double's ToString
            //      in my locle [Italian] gives "," insted of ".", and I
have an assembly  to make conversion.
            //      You can find howto do it easily on Programmer's guide or
on WebApi help
            var extent = new OpenLayers.Bounds(-87.865114442365922,
43.665065564837931, -87.595394059497067, 43.823852564430069);
            var mapOptions = {
                maxExtent: extent,
                maxResolution: 'auto'
            _map = new OpenLayers.Map('map_mg', mapOptions);
            var options = {
                isBaseLayer: true,
                buffer: 1,
                useOverlay: false,
                useAsyncOverlay: false,
                singleTile: true
                //, transitionEffect: 'resize'
            var params = {};
            params.mapName = '<%= GetMapName() %>';
            params.session = '<%= GetMapSession() %>';
            params.hideLayers = '<%= GetHidelayers() %>';
            params.showLayers = '<%= GetShowlayers() %>';
            // - Depending on Groups you can use
params.showGroups/hideGroups
            // - Making a selection os server side, you can get that
selection and pass here as param.selectionXml
            // - I have read somewhere that locale should be passed [and
that in some cases is mandatory] too, but it works for me even without
            var mg_layer = new OpenLayers.Layer.MapGuide("MapGuide Sheboygan
map", mg_url, params, options);
            _map.addLayer(mg_layer);
            _map.addControl(new OpenLayers.Control.MousePosition());
            _map.zoomToMaxExtent();
    </script>
</body>
</html>
Pietro Ianniello
mapguide-users mailing list
[hidden email]
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=4759356&i=0>
http://lists.osgeo.org/mailman/listinfo/mapguide-users
  _____
View message @
http://n2.nabble.com/MapGuide-with-Openlayers-Searching-for-Detailed-yet-Sim
ple-Development-Examples-tp4757480p4759356.html
To start a new topic under MapGuide Users, email
ml-node+1803227-182587645-98072 at n2.nabble.com
To unsubscribe from MapGuide Users, click
< (link removed)
3ZXJpbm5vdmF0aW9ucy5jb218MTgwMzIyN3wtMTY3MDQ3Mjg4>  here.
View this message in context: http://n2.nabble.com/MapGuide-with-Openlayers-Searching-for-Detailed-yet-Simple-Development-Examples-tp4757480p4759592.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100318/0ba00d6e/attachment.html
