[mapguide-users] Re: Reprojet Oracle layer
Zac Spitzer zac.spitzer at gmail.com
Tue May 4 08:01:42 EDT 2010
have you read the api docs? (if you want to do it programatically?)
otherwise you can do it all via maestro's gui
here's a good starting point
http://mapguide-central.ennoble.com.au/
z
On 4 May 2010 21:57, navya024 <navya.gudupi at gmail.com> wrote:
> Dear all,
> i want add a sdf layer to the existing map.for that is this the correct
> procedure?
> 1.create temporary feature resource?
> 2.create temeprary layer definition?
> If any sample code available ...............
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Reprojet-Oracle-layer-tp4978013p5002936.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
