[mapguide-users] Re: Mag Guide setup on II7 2008 Server Issue, Please help
Victoria (Tori) Myers tmyers at jeffersoncountywv.org
Thu May 6 08:37:28 EDT 2010
Steve,
	Thank you but which one on that site? The html that is displayed or
the PDF download because they are not the same. I did try both of those
without success. I will try again today.
Thanks again, Tori
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Steve G
Sent: Wednesday, May 05, 2010 6:03 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Re: Mag Guide setup on II7 2008 Server Issue,
Please help
Tori,
I am working on a Windows Server 2008 (64 bit) with IIS7 and have been able
to successfully get mapguide working a few times using the instructions
found at:
http://trac.osgeo.org/mapguide/wiki/MGOS2onVistaIIS7
Yes, the documentation is not great, but follow it exactly.  If you have
tried building the site, failed, and reinstalled mapguide (or made a "new"
connection to mapguide) be sure to completely remove the previous
application(s) from IIS.  You need to find the application window and remove
the applications (virtual paths to /mapguide, /mapguidemapagent, and
/mapguide/mapviewerajax).  If you simply remove the connection to the
mapguide website, I believe the applications persist.  At least that is what
I found.
I am having problems viewing raster ECW files (I've completed the same GDAL
FDO configuration as my XP box), but that is another story.
-Steve
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/Mag-Guide-setup-on-II7-2008-Server-Is
sue-Please-help-tp5010394p5011371.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
