[mapguide-users] Re: Generate KML with layers that are not based from WGS84 Datum
navya024 navya.gudupi at gmail.com
Fri May 21 00:32:34 EDT 2010
thats what i asked u.Is the sample code given by you is sufficient for
google earth integration.(if i modify the code for my layers).
and what is the first page that is to be executed in your code(is it
masters.php?)
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Generate-KML-with-layers-that-are-not-based-from-WGS84-Datum-tp1811769p5082657.html
