[mapguide-users] Mg Server often comes down
Zac Spitzer zac.spitzer at gmail.com
Sat May 22 03:38:17 EDT 2010
Also make sure your data isn't too detailed for the scale ranges your using,
which can overload and kill the server
Also validate your data as bad geom can cause crashes. Newer FDO addresses
some of this
And just forget raster
On 22 May 2010 02:30, "Dave Wilson" <dave.wilson at autodesk.com> wrote:
The version you are using is old and missing many improvements for
stability.
What data types are used in your map: SDF, Raster...etc
We need way more information before anyone can suggest anything other than
upgrade.
If the server crashes is there a stack trace or do you get a segmentation
fault with no information?
Is the server running out of memory?
Regards,
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-boun...
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100522/79d73b20/attachment.html
