[mapguide-users] Re: create redline line and polygon using king fdo and MGOS
djonio DJonio at miami-airport.com
Wed May 26 06:59:50 EDT 2010
Tony,
I am confused as to what you are trying to do. Are trying to implement
FDO/KingOra or are you trying to do a ODP.NET implementation? Two very
different things.
If you wish to understand ODP.NET go to
http://forums.oracle.com/forums/forum.jspa?forumID=146.
By the way, ODP.NET requires its corresponding 11g client. No, you do not
need an 11g database with an 11g client, a 10.2 database works just fine.
I suggested you install the Scribble application found in trac because it
has all the MG code needed to manipulate a dynamic SDF layer. Once you
understand that process, using KingOra, or any other provider for that
matter, is rather trivial.
r,
dennis
View this message in context: http://osgeo-org.1803224.n2.nabble.com/create-redline-line-and-polygon-using-king-fdo-and-MGOS-tp5039612p5102862.html
