[mapguide-users] Re: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
Jackie Ng jumpinjackie at gmail.com
Wed Oct 6 19:24:43 EDT 2010
Here's a dirty hack: have you tried injecting the bin path into the PATH
environment variable as part of your web application's Application_Start()
method?
The PATH environment variable is used for searching dlls.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Attempted-to-read-or-write-protected-memory-This-is-often-an-indication-that-other-memory-is-corrupt-tp5603440p5609384.html
