[mapguide-users] Re: WFS-T or modify shp on repositories and commit
Haris Kurtagic haris at sl-king.com
Tue Oct 19 06:18:13 EDT 2010
Yes, using GeoREST you can modify features in MapGuide (or FDO).
How to configure GeoREST to work with MapGuide you can read here:
http://code.google.com/p/georest/wiki/Documentation
After you unzipped geoREST there are samples which you can run easily
on your own (using built-in httpserver - georesthttpserver.exe). More
here: http://code.google.com/p/georest/wiki/Installation
Bellow is sample from docs how you connect GeoREST to MG layer and
enable Json and Xml rerpresentations   :
<RestConfig>
 <Data>
  <Resource uripart="property">
    <Source type="MapGuide">
    <FeatureSource>Library://Samples/Sheboygan/Data/Parcels.FeatureSource</FeatureSource>
    <FeatureClass>SHP_Schema:Parcels</FeatureClass>
    <ServerIp>192.168.0.3</ServerIp>
    <ServerPort >2812</ServerPort>
    </Source>
        <Representation renderer="JSON" pattern=".json"/>
        <Representation renderer="XML" pattern=".xml"/>
    </Resource>
 </Data>
</RestConfig>
To use OL for viewing and editing you need to use new OL layers which
are in OL sandbox.
You can check source of this html page to see how it is done:
http://www.sl-king.com/GeoRestMapSample/example1/rview.html
This Sheboygan editing sample was part of samples coming with GeoREST,
I think it is not part of it anymore.
I will add this sample to GeoREST as separate download, so you can run
it on your own.
Haris
On Tue, Oct 19, 2010 at 11:39 AM, ar_gaeta <ar_gaeta at yahoo.it> wrote:
> Hi all.
> So with GeoRest it's possible to modify the features loaded in a MapGuide
> site and their attribute tables?
> This is amazing and exaclty what I need!
> I've downloaded the software GeoRest and install it on my PC, I have MG-OS
> version 2.1 with Maestro, but I don't know how to make communicate the 2
> system...
> The features on the MapGuide site are visualized by deafult with OpenLayer?
> I mean: GeoRest work with OpenLayer, but I have to do somethng to load my
> features with OpenLayer or it is yet implemented by MapGuide?
> Please give me some steps to follow to better understand how works GeoRest
> and the logic to modify features!
> Tnx so much,
> Riccardo
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/WFS-T-or-modify-shp-on-repositories-and-commit-tp5634843p5650160.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
