[mapguide-users] Re: Problem connecting GeoREST to MapGuideOS 2.2 RC1
Haris Kurtagic haris at sl-king.com
Wed Oct 20 17:01:38 EDT 2010
it should be just http://localhost:8008/index.html   (without rest)
or something similar where you put your static files
with /rest/ it is rest uri which then correspond to some resource you
define trough config files
or http://localhost:8008/rest/hello
which should return hello back message from georest
in short, you need to put 'www' folder of georest under some different
virtual directory ( not /rest/ ) to serve those static files
I would also suggest you to try georesthttpserver.exe to quickly check
if it works for you for MG 2.2
Haris
On Wed, Oct 20, 2010 at 10:51 PM, Clonus <biogest at gmail.com> wrote:
> Try URL is
> http://localhost:8008/rest/index.html
> Thanks for your quick reply.
> Regards
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problem-connecting-GeoREST-to-MapGuideOS-2-2-RC1-tp5656169p5656592.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
