[mapguide-users] Re: Problem to show properties in Ajax viewer with ver. 2.2.0.5197
Jackie Ng jumpinjackie at gmail.com
Thu Oct 21 11:01:16 EDT 2010
Yes the 200 zoom level may not be appropriate for some cases, it was just
some number I pulled that would work 90% of the time.
A more ideal solution would be to return an envelope instead of returning
x/y as part of the response from getselectedfeatures, and have it re-use the
same code as the zoom to selection viewer command. That way you will be
always zooming to the full extents of that particular feature.
Such a change will probably have to be made after 2.2 given it's currently
RC with final release soon.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problem-to-show-properties-in-Ajax-viewer-with-ver-2-2-0-5197-tp5611272p5658993.html
