[mapguide-users] URL Parameters
GordonL gordon.luckett at arrowgeomatics.com
Fri Oct 22 09:02:38 EDT 2010
Using the Fusion URL Parameters you can do quite a lot.
- choose the default extents of the map ?extents=-118,45,-117,46
- choose the map (using patch http://trac.osgeo.org/fusion/ticket/65)
&mgmapresourceid=Library://Maps/myMap.MapDefinition  (this might be called
"theme" now)
-choose the Web Layout
Some other URL parameters are showgroups/hidegroups/showlayers
I love the URL parameters because you can save/bookmark them.
Only issue.  the hidelayers/showlayers does not update the legend - too bad.
Is there a fix?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/URL-Parameters-tp5662444p5662444.html
