[mapguide-users] Re: Problem connecting GeoREST to MapGuideOS 2.2 RC1
ar_gaeta ar_gaeta at yahoo.it
Mon Oct 25 04:06:17 EDT 2010
Hi all.
I've a problem with the feature "buildings". When I load the map trough the
url:
http://localhost:99/map/index.html
The error message that I got from Internet Explorer is:
'modifyControl' is not defined
line: 118
Carachter: 3
Code: 0
URI: http://localhost:99/map/index.html
'left' is null or is not an object
Line: 858
Carachter: 3
Code: 0
URI:
http://svn.openlayers.org/sandbox/simonpel/openlayers/openlayers/lib/OpenLayers/Layer/KMLGeoREST.js
The error message that I've got from Firefox is the same that I got when I
try to load other feature data than "building" or "parcel", to customize the
map. In this case:
Error in loading GML file /georest/rest/data/Propertymap/.kml?BBOX
-87.7841,43.691398,-87.6763,43.797520&COUNT=500
Error in loading GML file /georest/rest/data/Building/.kml?BBOX
And I'm not able to display any map.
1-What does these errors mean and how I can resolve them?
2-where is the config file that defines the url
"/georest/rest/data/Propertymap/*", and "/georest/rest/data/Building/*"?
3-which are the steps to load trough GeoRest other feature data than
"Building" and "Parcels"? I've tried to modify the "restcfg.xml" but it
doesn't work, I got error and I don't see the new features loaded. I must
change also the various "*.tpl" files?
Thanks for all.
System specification: MapGuide 2.2, Windows 7, GeoRest 1.0.8. I don't think
it's a problem of the MapGuide 2.2 because also with the 2.1 I've got the
same problems.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problem-connecting-GeoREST-to-MapGuideOS-2-2-RC1-tp5656169p5669779.html
