[mapguide-users] Re: Maestro Layout Task frame menu search filter syntax?
Jackie Ng jumpinjackie at gmail.com
Thu Oct 28 18:30:34 EDT 2010
This error can be the result of duplicate mapped properties in the search
results section of your search command.
If you are testing the latest builds of Maestro 3.0, it has enhanced Web
Layout validation rules to detect:
 - Duplicate command names
 - Orphaned menu entries
 - Duplicate property mappings in search commands
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Maestro-Layout-Task-frame-menu-search-filter-syntax-tp5100122p5684587.html
