[mapguide-users] Re: built in search tool question
Jackie Ng jumpinjackie at gmail.com
Thu Sep 9 22:09:40 EDT 2010
The "No response from feature selection request" message you get is when a
call to getselectedfeatures.aspx is empty. Generally speaking this should
not be happening.
Try using the viewer with Firefox (with the firebug extension enabled), run
your search command and look at the requests made to
getselectedfeatures.aspx:
 - What parameters is it sending?
 - What is the response (if any)?
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/built-in-search-tool-question-tp5514566p5516880.html
