[mapguide-users] URL Activated For Feature
Warren Medernach wmedernach at gmail.com
Thu Sep 16 18:56:27 EDT 2010
Hi Mark,
Is there a property on your data source that corresponds to the 1-5000
values?
If so, you can concat together a URL string to include the property.
ie, might look something like:
   concat('http://localhost/Valve Sketch Boundary/', <some property>,
'.pdf')
Hope this helps
Warren M
On Thu, Sep 16, 2010 at 4:33 PM, Mark Hedges <
hedgesm at cityofnorthlasvegas.com> wrote:
> Hi All,
> I have a Directory called PDF.  It is located at C:\PDF on my hard drive.
> This directory contains approximately 5,000 differently named PDF files.
> Using IIS I have set up a Virtual Directory called "Valve Sketch Boundary".
> The path for this directory is C:\PDF.  In MG Studio I have a layer created
> and in the URL Activated For Feature I have the following:
> 'http://localhost/Valve Sketch Boundary/1.pdf' (The 1.pdf is the name of
> the
> first of approximately 5,000 other PDF files.  Using MGOS I press Ctrl +
> select and the PDF file opens fine.  My issue is that I don't want to open
> the 1.pdf file everytime.  I want it to fire off the correct pdf file.  I
> have spent all afternoon searching this site and online and can't figure
> this out.
> Any Help Would Be Greatly Appreciated.
> Mark
> http://osgeo-org.1803224.n2.nabble.com/URL-Activated-For-Feature-tp5540681p5540681.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100916/0bb74332/attachment.html
