[mapguide-users] Regarding Tips to speed up mapguide
Zac Spitzer zac.spitzer at gmail.com
Fri Sep 24 03:43:02 EDT 2010
1. tiling once done should be a use benefit once tiled
2. the javascript compression will only aid initial page load times
what's your data like? if it's too detailed, that will slow down your server
ie if you have 5mm resolution data being rendered at 1:100k, that's
a lot of overhead
z
On Fri, Sep 24, 2010 at 5:29 PM, findjai <jai at ipssi.com> wrote:
> Hi All,
>  I am a user of Mapguide 2.0 version... In general i have found it is
> slower on clients browser. I wish if you all can help me in order quicken
> mapguide.
> I have tried a few suggestion i found on the internet.
> 1) Tiling - It does not increase the speed rather it slows down the process
> :( . Does it also depend on tile size? if yes, what can be optimum  size.
> 2) One of the patches provided by Zac to compress javascript ... i tried but
> could not see any visible difference :(
> Thanks all,
> Jai
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Regarding-Tips-to-speed-up-mapguide-tp5565830p5565830.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
