[mapguide-users] Re: Updating datasets in MGE. (sdf, or dwf)
frosty1_4me kbowman at cityofgp.com
Fri Aug 12 13:39:39 EDT 2011
I did some more digging.
The below error message is what I get when I first run the update and
overwrite the sdf.
"An exception occured in FDO component. SDF spatial index error."
After I restart the MGE server when I get that error and refresh the viewer,
I get the following message"
"The specified class was not found."
So, I went and reviewed the datasource in studio which was correct.  It had
all the data and feature types as expected.  I could browse the datasource
in studio correct.  I reviewed the layer which was failing and the Feature
class and geometry were no longer populated.
I tried Zach's suggestion to save the datasource even though it looked
correct, and then I went back to the layer in studio and it was all working
as it should have been.  The map also worked once again.
Gord, I looked at the settings in the serverconfig that we have and its
setup as follows:
DataConnectionPoolEnabled = 1
DataConnectionPoolExcludedProviders = none
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Updating-datasets-in-MGE-sdf-or-dwf-tp6677977p6681128.html
