[mapguide-users] Re: DWF layers look good in Design Review but out of whack in MapGuide
GIS4U johnniegis at gmail.com
Thu Dec 1 15:22:47 EST 2011
I have quite a few clients using DWF in MapGuide and I have never seen the
text rotation issue you are describing.
Do you have another version of MG running or just IMS 2012? If so, did it
work on previous MG version?
Don't uninstall Map 2010 until you've tested out 2012....
I have seen issues with DWF location in MG but never when they come out of
Map. Are you using Model space or paper space?
Jonathon
On Thu, Dec 1, 2011 at 11:50 AM, tmblackflag <steve.calpoly at gmail.com>wrote:
> I am using Map 3d 2010 to create the DWF and running IMS 2012, maybe that
> is
> the issue. I may try installing map 2012 and then exporting to see if it
> helps.
> I tried exporting the DWF from map and importing to studio, as well as
> publishing the dwf directly into studio with the built-in map 2010 publish
> utility.
> http://osgeo-org.1803224.n2.nabble.com/DWF-layers-look-good-in-Design-Review-but-out-of-whack-in-MapGuide-tp7047678p7051831.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20111201/481d3b2a/attachment.html
