[mapguide-users] MaestroAPI 4 and MGOS 2.2 - empty/blank/transparent map
Hans Milling hm at geograf.dk
Fri Dec 2 07:59:34 EST 2011
Hi, I am trying one of the samples from the MapGuide API 4.0 website.
Using MGOS 2.2 I have set up a simple map with a sigel layer based on a
MapInfo tab/ind/map/dat files.
Using MapGuide Maestro 3.5 (And 4.0 RC1) I can see the layer and map, no
problems and no validation errors.
But when I run the following sample code that just saves the map as a PNG
image, the image is just a transparent blank image but with the correct
with/height. Does anyone have any clue what I am missing?
			        Uri host = new
Uri("http://msvm/mapguide/mapagent/mapagent.fcgi");
			        IServerConnection conn =
ConnectionProviderRegistry.CreateConnection("Maestro.Http",
"Url", host.ToString(), "Username",
"Administrator", "Password", "admin");
			        IMappingService mapSvc =
(IMappingService)conn.GetService((int)ServiceType.Mapping);
			        ResourceIdentifier resId = new
ResourceIdentifier("Library://Test/MyMap.MapDefinition");
			        IMapDefinition mdf =
(IMapDefinition)conn.ResourceService.GetResource(resId);
			        double metersPerUnit = 1.0;
			/*      if (!string.IsNullOrEmpty(mdf.CoordinateSystem))
			          MgCoordinateSystemFactory factory =
new MgCoordinateSystemFactory(); // <-- This Throws a target of an
invocation exception, but never mind
			          MgCoordinateSystem cs =
factory.Create(mdf.CoordinateSystem);
			          metersPerUnit =
cs.ConvertCoordinateSystemUnitsToMeters(1.0);
			        ResourceIdentifier rtMapId = new
ResourceIdentifier(resId.Name, ResourceTypes.RuntimeMap,
conn.SessionID);
			        RuntimeMap map = mapSvc.CreateMap(rtMapId,
mdf, metersPerUnit);
			        map.DisplayWidth = 640;
			        map.DisplayHeight = 480;
			        map.DisplayDpi = 96;
			        map.BackgroundColor = Color.White;
			        map.DataExtent =
ObjectFactory.CreateEnvelope(505468, 6276258, 539925, 6320454);
			        map.Save();
			        byte[] buf = new byte[1024];
			        using (Stream stream =
mapSvc.RenderDynamicOverlay(map, null, "PNG"))
			          using (var fs = new
FileStream("RenderMap.png", FileMode.OpenOrCreate))
			            int read = 0;
			            do
			              read = stream.Read(buf,
0, buf.Length);
			              fs.Write(buf, 0, read);
			            } while (read > 0);
Regards Hans Milling...
View this message in context: http://osgeo-org.1803224.n2.nabble.com/MaestroAPI-4-and-MGOS-2-2-empty-blank-transparent-map-tp7054607p7054607.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20111202/e2de5b71/attachment.html
