[mapguide-users] RE: Points from Sql/ODBC data source not showing
soudemans soudemans at ruekert-mielke.com
Tue Dec 6 16:36:51 EST 2011
GordonL wrote
> In your final view in SQL Server 2008, you should just create a Point
> object with your two x and y columns.
> like this:
> /select geometry::Point(g.PNT_X,g.PNT_Y,0) as GEOM
> 	  FROM tbMYTABLE g/
> Then you can use the FDO for SQL Server Spatial rather than ODBC.
Thanks Gordon,
I'll have to try that next, though my level of frustration with the FDOs not
working right is beginning to reach a boiling point.  Point and case, I
thought I'd try my hand (again) at creating a simple Join in the
FeatureSource editor.  This is to link some SQL data to SDF line features
(no points).  So I created an ODBC - SQL Server connection (the only
available for this purpose) to my data source.  I previewed the data which
is a SQL View that uses a CASE statement as follows:
SELECT PipeID,
    (CASE
         WHEN [WorkType] IS NULL THEN 'Yellow'
         WHEN [WorkType] IN (N'Maintenance', N'Televising') AND
MonthsNotCleaned > 60 THEN 'Red'
         WHEN [WorkType] IN (N'Root Cutting') AND MonthsNotCleaned > 12 THEN
'Red'
         WHEN [WorkType] IN (N'Grease', N'Trouble') AND MonthsNotCleaned > 3
THEN 'Red'
         ELSE 'Green'
    END) AS Condition
FROM dbo.qrySanMainLastCleaning
The data previews exactly as it should in the data source editor, so far so
good.  now I go to my sdf data source and add a join to my query.  No
errors, but when I preview the data the pipeID comes in, but the Condition
calculated field shows up as all nulls.  The map shows the default color
only which means that this is not a preview issue. Is this something I can't
do?  I also tried this with a SHP data source, same result.  I will let this
go for now and try Gordon's suggestion first.
Hey, thanks to you Gordon and anyone else looking at this stuff.  Your help
is much appreciated.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Points-from-Sql-ODBC-data-source-not-showing-tp7021115p7068485.html
