[mapguide-users] Re: Mapagent FCGI Not Found
GIS4U johnniegis at gmail.com
Thu Dec 8 15:49:33 EST 2011
OK, for what it is worth, I have had strange but similar issues but it does
not appear consistently so that I can say: "this is the answer". When I
have had it, I have found that adding mapagent.fcgi to the default
documents and moving it to the top of the list will solve it.
Don't know why...but it's what's worked for me so maybe it will for you too.
Best regards,
Jonathon
On Thu, Dec 8, 2011 at 10:24 AM, John Grego <johng at vtnnv.com> wrote:
> The application pool is tied to the built-in “ApplicationPoolIdentity”
> account in IIS 7.5.  I’ve given file/folder access to the IUSR and
> IIS_IUSRS
> accounts, as well as implicit permissions for the application pool identity
> per instructions found at this link:
> http://learn.iis.net/page.aspx/624/application-pool-identities/
> If I set the application pool “Enable 32-Bit Applications” setting to True,
> I will get a 500 error and cannot open the Web Tier Tests index.html file.
> It may be relevant that I did experience this same inexplicable behavior
> when prompted to activate IMS after running successfully in trial mode for
> 30 days, but after the activation everything seemed to be resolved, until
> the occurrence of the 404.17 error.  The product currently appears to be
> licensed and activated properly.
> I’ve uninstalled/re-installed IIS 7.5 and recreated my web server, as well
> as manually configure the web server extensions for IIS 7.5.  Could it be
> that I may have corrupted the Windows registry and IIS with my multiple
> uninstall/re-install iterations?
> -John Grego
> http://osgeo-org.1803224.n2.nabble.com/Mapagent-FCGI-Not-Found-tp1804128p7075337.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20111208/beee5070/attachment.html
