[mapguide-users] Unable to select a point using Fusion viewer
Iulia Tamas iulia_tamas30 at yahoo.com
Mon Dec 12 02:21:57 EST 2011
Hello,
Thank you for your reply. I have reproduced the issue in firefox also, but I get no error message in firebug, only the alert with the message "Problem:
The application encountered a problem and could not finish the operation you just requested properly."
With DWF viewer all works ok (the point can be selected) but with Ajax when I select a point, I get an alert with all the values /properties from the non-spatial table. After I press OK, i get the properties of the point in the "Properties" frame but the point is still not selected (no error message in firebug).
Thank you,
Iulia
To: Iulia Tamas <iulia_tamas30 at yahoo.com>; MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Sent: Saturday, December 10, 2011 6:41 AM
Subject: Re: [mapguide-users] Unable to select a point using Fusion viewer
can you try it in firefox with firebug and see if you can see any
further error messages? the embedded IE in studio makes
debugging very hard
On Sat, Dec 10, 2011 at 1:23 AM, Iulia Tamas <iulia_tamas30 at yahoo.com> wrote:
> Hello,
> Message is displayed when selecting a point on the Map using Fusion viewer.
> The data is stored in non-spatial table in Oracle and a primary key is set
> on the table.
> Other layers that use  a .sdf file as a data source can be selected.
> I'm using Mapguide 2.2 on 64 bit machine.
> I've attached an image with the  received message.
> Has anybody encountered the same problem?
> Thank You,
> Iulia
> mapguide-users mailing list
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20111211/93839257/attachment.html
