[mapguide-users] Buffer error
Olcay Ebcin (Coğrafi Bilgi Sistemleri Şube Müdürü) OEBCIN at iski.gov.tr
Thu Dec 22 12:37:01 EST 2011
I use fusion viewer and Autodesk mapserver 2012.
Olcay Ebcin
22 Ara 2011 tarihinde 19:00 saatinde, "mapguide-users-request at lists.osgeo.org" <mapguide-users-request at lists.osgeo.org> şunları yazdı:
> Send mapguide-users mailing list submissions to
>    mapguide-users at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>    http://lists.osgeo.org/mailman/listinfo/mapguide-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>    mapguide-users-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of mapguide-users digest..."
> Today's Topics:
>   1. BUFFER ERROR
>      ( Olcay Ebcin (Co?rafi Bilgi Sistemleri ?ube M?d?r?) )
>   2. Re: BUFFER ERROR (Zac Spitzer)
>   3. Re: Re: Cannot SetSelectionXML using KingOracle as    provider
>      (Iulia Tamas)
>   4. SV: [mapguide-users] Re: adding a points layer from ODBC
>      problem (Von Barth, Peter)
> Message: 1
> Date: Thu, 22 Dec 2011 00:44:31 +0200
> From: " Olcay Ebcin (Co?rafi Bilgi Sistemleri ?ube M?d?r?) "
>    <OEBCIN at iski.gov.tr>
> Subject: [mapguide-users] BUFFER ERROR
> To: "mapguide-users at lists.osgeo.org" <mapguide-users at lists.osgeo.org>
> Message-ID:
>    <5772283EB04023448334553E21A96282015636D0E86A at MERCAN.iski.local>
> Content-Type: text/plain; charset="iso-8859-9"
> Hi,
> When I try to create a buffer on a point layer via fusion, I get the following error message.
> Buffer Error
> The coordinate system conversion failed. A point, a portion of a line segment or a portion of the region, is outside of the mathematical domain of the coordinate system.
> The problem exists when Point layer has SRID of 23035 and Map is WGS84.pseudoMercator.
> if Point  has SRID of 4326  and Map is WGS84.pseudoMercator Buffer Created Successfuly.
> Any help is appreciated.
> Regards,
> Olcay Ebcin
> Message: 2
> Date: Thu, 22 Dec 2011 10:58:11 +1100
> From: Zac Spitzer <zac.spitzer at gmail.com>
> Subject: Re: [mapguide-users] BUFFER ERROR
> To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
> Message-ID:
>    <CAArGWaTpzCiqbaRtvHMt-RDWUq4OvZfJq-wMR1P7BQMoVpiK7g at mail.gmail.com>
> Content-Type: text/plain; charset=UTF-8
> which viewer? which version of mapguide?
> 2011/12/22 Olcay Ebcin (Coğrafi Bilgi Sistemleri Şube Müdürü)
> <OEBCIN at iski.gov.tr>:
>> Hi,
>> Buffer Error
>> Regards,
>> Olcay Ebcin
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
> Message: 3
> Date: Thu, 22 Dec 2011 02:20:10 -0800 (PST)
> From: Iulia Tamas <iulia_tamas30 at yahoo.com>
> Subject: Re: [mapguide-users] Re: Cannot SetSelectionXML using
> Message-ID:
>    <1324549210.28158.YahooMailNeo at web122401.mail.ne1.yahoo.com>
> Content-Type: text/plain; charset="us-ascii"
> Hello,
> Thank you for you help, the problem was that  "NAME" is a reserved word in Oracle.
> Another issue is that I can't manage to get the geometry from Oracle. Could you hep me with some sample code?
> Thank You
> From: GordonL <gordon.luckett at arrowgeomatics.com>
> To: mapguide-users at lists.osgeo.org
> Sent: Tuesday, December 20, 2011 7:03 PM
> Subject: [mapguide-users] Re: Cannot SetSelectionXML using KingOracle as provider
> Perhaps because "NAME" is a reserved word in Oracle?
> properties->Add(new MgStringProperty('NAME',
> $featureReader->GetString('NAME')));
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Cannot-SetSelectionXML-using-KingOracle-as-provider-tp7112491p7112524.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20111222/d5dda9fa/attachment-0001.html
> Message: 4
> Date: Thu, 22 Dec 2011 12:50:37 +0100
> From: "Von Barth, Peter" <Peter.vonBarth at eon.se>
> Subject: SV: [mapguide-users] Re: adding a points layer from ODBC
>    problem
> Message-ID:
>    <E523FA0A43AF8C4297927113B5B8224B02E0BEF0 at SME1085.dom1.e-ssi.net>
> Content-Type: text/plain; charset="iso-8859-1"
> Hi!
> I Have the same problem. And I'm sorry to say that the only way I could fix it was to roll back to MGOS 2.1 in this version it works.
> Here�s a link to my thread http://osgeo-org.1803224.n2.nabble.com/ODBC-Connection-tp6355171p6357829.html
> If anyone has a solution to this using 2.2 I would be very interested in reading the solution
> //Peter
> Fr�n: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] F�r nazeitgeist
> Skickat: den 21 december 2011 07:26
> Till: mapguide-users at lists.osgeo.org
> �mne: [mapguide-users] Re: adding a points layer from ODBC problem
> i already try to preview the feature data using 32bit and 64bit PC but same problem occurred.. An exception occurred in FDO component. Internal error even when i try it on maestro 4..same problem... does anyone have the same problem and knows how to solve this problem.. ? help me plz.. i'm a newbie..
> View this message in context: Re: adding a points layer from ODBC problem<http://osgeo-org.1803224.n2.nabble.com/adding-a-points-layer-from-ODBC-problem-tp7107449p7114259.html>
> Sent from the MapGuide Users mailing list archive<http://osgeo-org.1803224.n2.nabble.com/MapGuide-Users-f1803227.html> at Nabble.com.
> URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20111222/64a9c83c/attachment-0001.html
> End of mapguide-users Digest, Vol 60, Issue 23
