[mapguide-users] RE: Alias to external DWF files
Brigl markus.briglmeir at autodesk.com
Wed Feb 9 11:37:34 EST 2011
How would I use the new feature source?
more precisely: the new feature source is available as an alias then, how would I create a layer based on it?
From: BTenBroeck [via OSGeo.org] [mailto:ml-node+5993365-266887860-147591 at n2.nabble.com]
Sent: Freitag, 4. Februar 2011 18:49
To: Markus Briglmeir
Subject: Re: Alias to external DWF files
If you go into the serverconfig.ini file, all the way at the bottom there is a heading for unmanaged datasources. Put something like this in that section:
DWF = F:\Projects\GP\Data\DWF
That file will be in your Server\bin directory
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1803224.n2.nabble.com/Alias-to-external-DWF-files-tp5992002p5993365.html
To unsubscribe from Alias to external DWF files, click here<http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5992002&code=bWFya3VzLmJyaWdsbWVpckBhdXRvZGVzay5jb218NTk5MjAwMnwtNDUzNjM2MzU1>.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Alias-to-external-DWF-files-tp5992002p6008446.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110209/a41676bf/attachment.html
