[mapguide-users] ECW for mapguide 2.2 beta version
Jason Birch jason at jasonbirch.com
Mon Feb 14 03:35:46 EST 2011
Have you tried following the debug steps for the gdal provider? They
are available from the fdo Trac site, and I think also from mapguide's
trac.
I wonder if there are problems with spaces in filenames...
On 2011-02-13, ehsan <ehsan85 at yahoo.com> wrote:
> My data for ecw raster image contain satellite image, it actually to use
> with
> tab for mapinfo, now i'm trying to view ecw raster image using mapguide with
> other layer from mapinfo tab file.
> This is the xml code for this resource
> <?xml version="1.0" encoding="utf-8"?>
> <fdo:DataStore xmlns:xs="http://www.w3.org/2001/XMLSchema"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xlink="http://www.w3.org/1999/xlink"
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:fdo="http://fdo.osgeo.org/schemas"
> xmlns:fds="http://fdo.osgeo.org/schemas/fds">
>   <gml:DerivedCRS gml:id="Default">
>     <gml:metaDataProperty>
>       <gml:GenericMetaData>
>         <fdo:SCExtentType>dynamic</fdo:SCExtentType>
>         <fdo:XYTolerance>0.001000</fdo:XYTolerance>
>         <fdo:ZTolerance>0.001000</fdo:ZTolerance>
>       </gml:GenericMetaData>
>     </gml:metaDataProperty>
>     <gml:remarks>System generated default FDO Spatial Context</gml:remarks>
>     <gml:srsName>Default</gml:srsName>
>     <gml:validArea>
>       <gml:boundingBox>
>         <gml:pos>-10000000 -10000000</gml:pos>
>         <gml:pos>10000000 10000000</gml:pos>
>       </gml:boundingBox>
>     </gml:validArea>
>     <gml:baseCRS>
>       <fdo:WKTCRS gml:id="Default">
>         <fdo:WKT>LOCAL_CS["*XY-MT*",LOCAL_DATUM["*X-Y*",10000],UNIT["Meter",
> 1],AXIS["X",EAST],AXIS["Y",NORTH]]</fdo:WKT>
>       </fdo:WKTCRS>
>     </gml:baseCRS>
>     <gml:definedByConversion
> xlink:href="http://fdo.osgeo.org/coord_conversions#identity" />
>     <gml:derivedCRSType
> codeSpace="http://fdo.osgeo.org/crs_types">geographic</gml:derivedCRSType>
>     <gml:usesCS xlink:href="http://fdo.osgeo.org/cs#default_cartesian" />
>   </gml:DerivedCRS>
>   <xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
> xmlns:default="http://fdo.osgeo.org/schemas/feature/default"
> targetNamespace="http://fdo.osgeo.org/schemas/feature/default"
> elementFormDefault="qualified" attributeFormDefault="unqualified">
>     <xs:annotation>
>       <xs:appinfo source="http://fdo.osgeo.org/schemas" />
>     </xs:annotation>
>     <xs:element name="default" type="default:defaultType" abstract="false"
> substitutionGroup="gml:_Feature">
>       <xs:key name="defaultKey">
>         <xs:selector xpath=".//default" />
>         <xs:field xpath="FeatId" />
>       </xs:key>
>     </xs:element>
>     <xs:complexType name="defaultType" abstract="false"
> fdo:hasGeometry="false">
>       <xs:annotation>
>       </xs:annotation>
>       <xs:complexContent>
>         <xs:extension base="gml:AbstractFeatureType">
>           <xs:sequence>
>             <xs:element name="FeatId">
>               <xs:annotation>
>               </xs:annotation>
>               <xs:simpleType>
>                 <xs:restriction base="xs:string">
>                   <xs:maxLength value="256" />
>                 </xs:restriction>
>               </xs:simpleType>
>             </xs:element>
>             <xs:element name="Image" type="fdo:RasterPropertyType"
> fdo:defaultImageXSize="1024" fdo:defaultImageYSize="1024"
> fdo:srsName="Default">
>               <xs:annotation>
>                 <xs:appinfo source="http://fdo.osgeo.org/schemas">
>                   <fdo:DefaultDataModel dataModelType="Bitonal"
> dataType="Unknown" organization="Pixel" bitsPerPixel="1" tileSizeX="256"
> tileSizeY="256" />
>                 </xs:appinfo>
>               </xs:annotation>
>             </xs:element>
>           </xs:sequence>
>         </xs:extension>
>       </xs:complexContent>
>     </xs:complexType>
>   </xs:schema>
>   <SchemaMapping provider="OSGeo.Gdal.3.2" name="default"
> xmlns="http://fdogrfp.osgeo.org/schemas">
>     <complexType name="defaultType">
>       <complexType name="RasterTypeType">
>         <RasterDefinition name="images">
>           <Location name="C:\IMAGE_SATELIT\">
>             <Feature name="Kuala Terengganu">
>               <Band name="RGB" number="1">
>                 <Image frame="1" name="Kuala Terengganu.ecw">
>                   <Bounds>
>                     <MinX>-10000000</MinX>
>                     <MinY>-10000000</MinY>
>                     <MaxX>10000000</MaxX>
>                     <MaxY>10000000</MaxY>
>                   </Bounds>
>                 </Image>
>               </Band>
>             </Feature>
>           </Location>
>         </RasterDefinition>
>       </complexType>
>     </complexType>
>   </SchemaMapping>
> </fdo:DataStore>
> the projection that mapguide assume that i can see it show only Default,
> with
> in mapinfo i use
> CoordSys Earth Projection 30, 47, "m", 102.8952083, 4.946141667, 0, 0
> Units "m"
> for the ecw file
> because the image does not appear in mapguide i try to override it in
> Mapguide Maestro by using:
> Coordinate Category : Malaysia
> Coordinate System : State of Terengganu, Paninsula Malaysia, Sears Chain
> (MAL-CTER)
> Thank you..
> http://osgeo-org.1803224.n2.nabble.com/ECW-for-mapguide-2-2-beta-version-tp6022062p6022541.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
