[mapguide-users] Re: Syntax to set Active layer in Mapguide via Fusion
BTenBroeck billtenbroeck at gmail.com
Wed Feb 23 15:12:59 EST 2011
That was what I needed Mike... thank you.
Since it's for a Report, it's useful to pre-exclude items on other
layers, both because there is not as much iteration that needs to be
done, as well as preventing highlighting unnecessary features.
On 2/22/2011 10:04 AM, Mike Adair [via OSGeo.org] wrote:
> The get/setActiveLayer methods are in the Map object (ie. the
> Fusion.getWidgetById('map') object) since the active layer can be set
> to any of the layers (ie. more than just aMaps[0])
> Mike
> On 21/02/2011 6:31 AM, BTenBroeck wrote:
>> No, I'm trying to set a layer active, and then tell the selection
>> tool to only use items on the active layer. I have the second piece
>> working , but I don't want the user to have to manually set the layer
>> active.
>> On 2/20/2011 7:39 PM, zspitzer [via OSGeo.org] wrote:
>>> what are you trying to do, turn a layer on?
>>> On Mon, Feb 21, 2011 at 2:39 AM, BTenBroeck <[hidden email]
>>> </user/SendEmail.jtp?type=node&node=6047126&i=0&by-user=t&by-user=t>> wrote:
>>> > Hello all. This is a cross-post from the Fusion-users, as I had no
>>> luck
>>> > getting a response there. Hopefully the heavier traffic over here
>>> may bear
>>> > fruit. :)
>>> > As the subject says, I'm trying to figure out the appropriate
>>> syntax to
>>> > set the active layer via Javascript in Fusion.
>>> > What I've tried is:
>>> >         var oMap = Fusion.getWidgetById('Map').aMaps[0];
>>> >         var activeLayer = oMap.setActiveLayer("Parcels");
>>> > which seems like it's appropriate by looking at the Map.js widget.
>>> > However, it tossess an error, and if I view in Firebug, there is
>>> no method
>>> > in oMap for
>>> > setActiveLayer or getActiveLayer as I would expect.
>>> > If anyone has a clue, or can point me in the right direction, I would
>>> > appreciate it.
>>> > Thanks
>>> > View this message in context:
>>> http://osgeo-org.1803224.n2.nabble.com/Syntax-to-set-Active-layer-in-Mapguide-via-Fusion-tp6045953p6045953.html
>>> <http://osgeo-org.1803224.n2.nabble.com/Syntax-to-set-Active-layer-in-Mapguide-via-Fusion-tp6045953p6045953.html?by-user=t&by-user=t&by-user=t>
>>> > Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> > _______________________________________________
>>> > mapguide-users mailing list
>>> > [hidden email]
>>> </user/SendEmail.jtp?type=node&node=6047126&i=1&by-user=t&by-user=t>
>>> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> Zac Spitzer
>>> Solution Architect / Director
>>> Ennoble Consultancy Australia
>>> http://www.ennoble.com.au
>>> http://zacster.blogspot.com
>>> +61 405 847 168
>>> [hidden email]
>>> </user/SendEmail.jtp?type=node&node=6047126&i=2&by-user=t&by-user=t>
>>> If you reply to this email, your message will be added to the
>>> discussion below:
>>> http://osgeo-org.1803224.n2.nabble.com/Syntax-to-set-Active-layer-in-Mapguide-via-Fusion-tp6045953p6047126.html
>>> <http://osgeo-org.1803224.n2.nabble.com/Syntax-to-set-Active-layer-in-Mapguide-via-Fusion-tp6045953p6047126.html?by-user=t&by-user=t>
>>> To unsubscribe from Syntax to set Active layer in Mapguide via
>>> Fusion, click here
>>> <http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=6045953&code=YmlsbHRlbmJyb2Vja0BnbWFpbC5jb218NjA0NTk1M3w1MzM0ODEyNTU=&by-user=t&by-user=t>.
>> View this message in context: Re: Syntax to set Active layer in
>> Mapguide via Fusion
>> <http://osgeo-org.1803224.n2.nabble.com/Syntax-to-set-Active-layer-in-Mapguide-via-Fusion-tp6045953p6048362.html?by-user=t>
>> <http://osgeo-org.1803224.n2.nabble.com/MapGuide-Users-f1803227.html?by-user=t>
>> at Nabble.com.
>> [hidden email]  </user/SendEmail.jtp?type=node&node=6052647&i=0>
> [hidden email] </user/SendEmail.jtp?type=node&node=6052647&i=1>
> discussion below:
> http://osgeo-org.1803224.n2.nabble.com/Syntax-to-set-Active-layer-in-Mapguide-via-Fusion-tp6045953p6052647.html
> To unsubscribe from Syntax to set Active layer in Mapguide via Fusion,
> click here
> <http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=6045953&code=YmlsbHRlbmJyb2Vja0BnbWFpbC5jb218NjA0NTk1M3w1MzM0ODEyNTU=>.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Syntax-to-set-Active-layer-in-Mapguide-via-Fusion-tp6045953p6057695.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110223/b63a3223/attachment.html
