[mapguide-users] Re: Is it possible to convert Lat and Long value to X Y (AJAX viewer)
Greg gbneff at cid.utah.gov
Fri Feb 25 15:20:32 EST 2011
I was able to do it using something Like this:
MgUserInformation userInfo = new MgUserInformation(sessionId);
        MgSiteConnection siteConnection = new MgSiteConnection();
        siteConnection.Open(userInfo);
        MgResourceService resService =
(MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
        MgMap map = new MgMap();
        map.Open(resService, "Cid_Map");
        //create coord sys
        MgCoordinateSystemFactory coordFactory = new
MgCoordinateSystemFactory();
        String srsMapDef = map.GetMapSRS().ToString();
        MgCoordinateSystem mapCS = coordFactory.Create(srsMapDef);
        MgGeometryFactory geometryFactory = new MgGeometryFactory();
        MgCoordinate coordLatLon;
        MgCoordinate coordXY;
        ArrayList X = new ArrayList();
        ArrayList Y = new ArrayList();
        Response.Write("<table>");
        for (i = 0; i < lat.Count; i++)
            coordLatLon =
geometryFactory.CreateCoordinateXY(Convert.ToDouble(lon[i]),
Convert.ToDouble(lat[i]));
            coordXY = mapCS.ConvertFromLonLat(coordLatLon);
            X.Add(coordXY.GetX().ToString());
            Y.Add(coordXY.GetY().ToString());
            if (i < 108)
                Response.Write("<tr class='colData'><td>" + X[i] +
"</td><td>" + Y[i] + "</td></tr>");
        Response.Write("</table>");
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Is-it-possible-to-convert-Lat-and-Long-value-to-X-Y-AJAX-viewer-tp6023213p6065880.html
