[mapguide-users] mginstallubuntu.sh and serverconfig.ini
Trevor Wekel trevor_wekel at otxsystems.com
Mon Feb 28 11:52:34 EST 2011
Hi Martin,
The MapGuide Server daemon may not be starting successfully.  Do a "ps -auwx" to see if mgserver is in the process list.  If it is not, try adding the following directory as root "mkdir /var/lock/mgserver".  If adding the directory resolves the issue, please open a defect.
If this does not work, try running mgserver.sh.  There may be unresolved shared library references on Ubuntu 10 which are preventing the MapGuide server process from starting up.
Regards,
Trevor
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Martin Fafard
Sent: February 28, 2011 9:27 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] mginstallubuntu.sh and serverconfig.ini
Thank you Trevor, it runs with RC3
But now I "Cannot establish connection" with user Administrator and passwd admin (url: http://myipaddress/mapguide/mapadmin/login.php)
Any idea?
I try this with Ubuntu LTS 10.04...
Martin
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110228/f2a9067b/attachment.html
