[mapguide-users] mginstallubuntu.sh and serverconfig.ini
Martin Fafard martin.fafard at geoprojection.com
Mon Feb 28 14:40:59 EST 2011
Trevor
Yes, the connection is now ok with "mkdir /var/lock/mgserver".
I create a ticket
Martin
Trevor Wekel a écrit :
> Hi Martin,
> The MapGuide Server daemon may not be starting successfully.  Do a "ps
> --auwx" to see if mgserver is in the process list.  If it is not, try
> adding the following directory as root "mkdir /var/lock/mgserver".  If
> adding the directory resolves the issue, please open a defect.
> If this does not work, try running mgserver.sh.  There may be
> unresolved shared library references on Ubuntu 10 which are preventing
> the MapGuide server process from starting up.
> Regards,
> Trevor
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Martin
> Fafard
> *Sent:* February 28, 2011 9:27 AM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] mginstallubuntu.sh and serverconfig.ini
> Thank you Trevor, it runs with RC3
> But now I "Cannot establish connection" with user Administrator and
> passwd admin (url: http://myipaddress/mapguide/mapadmin/login.php)
> Any idea?
> I try this with Ubuntu LTS 10.04...
> Martin
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110228/ab8c6ffd/attachment.html
