[mapguide-users] mapguide 2.1 dynamic overlay problem
girish kumar bv girish778 at rediffmail.com
Fri Jul 8 02:57:52 EDT 2011
I am creating a xml marker layer to be overlayed on the existing map
layer on search, initially before search map coordinates are X:
301620.238896, Y: 2343288.901354 (DEGREE) however the coordinates change
to X: NaN, Y: NaN (DEGREE) and does not display the xml layer on
existing map after search. Can anyone suggest a solution for the above
problem.
However, even when i try to make an selection on the layer programmatically, then also i face the same problem
projection of shapefiles used are : UTM - wgs84
xml marker projection -
 String
UTMWkt="PROJCS[\"WGS_1984_UTM_Zone_43N\",GEOGCS[\"GCS_WGS_1984\",DATUM[\"D_WGS_1984\",SPHEROID[\"WGS_1984\",6378137.0,298.257223563]],PRIMEM[\"Greenwich\",0.0],UNIT[\"Degree\",0.0174532925199433]],PROJECTION[\"Transverse_Mercator\"],PARAMETER[\"False_Easting\",500000.0],PARAMETER[\"False_Northing\",0.0],PARAMETER[\"Central_Meridian\",75.0],PARAMETER[\"Scale_Factor\",0.9996],PARAMETER[\"Latitude_Of_Origin\",0.0],UNIT[\"Meter\",1.0]]";
I am attaching the url from which the application can be accessed
http://118.102.160.131/mapguide2011/nmc/ajaxtiledviewersample.jsp?DomainName=nmc
regards,
girish
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110708/88fe5546/attachment.html
