[mapguide-users] Re: Can't get fusion to work using Sheboygan and Google Maps
Jackie Ng jumpinjackie at gmail.com
Wed Jul 13 21:48:10 EDT 2011
The "The value cannot be less than or equal to zero" error is a nonsense
error generally caused by the Map Definition not being visible in the
current viewport.
You said you converted your Map Definition to PseudoMercator. Did you also
manually convert the extent coordinates? Maestro cannot transform extents to
PseudoMercator coordinates, and thus manual conversion is required.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Can-t-get-fusion-to-work-using-Sheboygan-and-Google-Maps-tp6580834p6581584.html
